early access build 4674 - also 4673 where I first noticed it -
shader transparency in overlay not working. will only go to an on/off state
also some video weirdness when trying to use VDJ video in TellyVisuals
instead of this
when selecting VDJ Video as image I get this and it will not de-select.
I have to delete the panel and re-create to get functionality back.
instead of this
geposted Mon 12 Nov 18 @ 8:50 pm
Shader transparency works fine for me
geposted Tue 13 Nov 18 @ 4:03 am
update - the tellyvisuals menu issue ONLY occurs when using shader -
if shader is off in overlay it doesn't do it and reverts back to normal function
the only changes since last time I used the shader transparency was 1 - with an earlier build - no idea how far back that was. and 2 - there was a java update. have made no other changes to computer in last few months.
geposted Tue 13 Nov 18 @ 5:05 am
i'm starting to really like screengrab as a handy way of recording things... not quite as good as screen capture software with more recording options yet. but it's getting to be hand to record what's going on
geposted Tue 13 Nov 18 @ 5:25 am
