I want deck 4 for line in only. But when I double click a track instead of dragging it it gets loaded to deck 4. How do I make sure tracks only get loaded to decks 1,2 (and possibly deck 3 if I am feeling adventurous) without dragging them onto them all of the time?
geposted Fri 30 Nov 18 @ 12:01 am
Anyone?
geposted Wed 12 Dec 18 @ 9:33 am
Close VDJ then go to the XML of the skin you're using (I'm assuming it's a 4 deck one) and in the first line you will see nbdecks="4"
Change the value to 3 then save the XML back to the ZIP folder and it will fool VDJ in to thinking there are only 3 decks, meaning the 4th one won't load if you have the other three active.
Keith
Keith
geposted Wed 12 Dec 18 @ 10:15 am
