I'm constanly having problems with tags.
After tagging new files...with time these tags are gone.
In december/january i created tags in new musicfiles (audio as well video).
When i look them today...tags are gone.
It occurs in certain tagfields: year, genre, comment....no problem with names of artist and tracks.
The tags i wrote and lost are visible although, beneath the tagfield (see my attached image)
What is this problem...what causes it?
geposted Sun 10 Mar 19 @ 12:51 am
Do you have the option “readonly” set?
geposted Sun 10 Mar 19 @ 5:02 am
Phil, "readonly" is set to "no".
The problem occurs randomly.
Let's say i tagged 10 files on a day....6 of them lost tags.
geposted Sun 10 Mar 19 @ 1:04 pm
I notice the drive letter is F: so is that an external drive?
Do you ever unplug the drive whilst VDJ is still running? When you unplug, do you eject properly via the OS or just yank it out?
geposted Sun 10 Mar 19 @ 2:46 pm
Hi, i do not a reason why i should unplug the external drvive while vdj is running, so i do,n't.
I use the notebook and ext drive only for prework of gigs and actually working with vdj.
geposted Sun 10 Mar 19 @ 11:35 pm
hummm... are you sure not to have a plugin/config issue preventing VDJ to exit cleanly ?
if so you can loose some unsaved data: last config change, recent custom buttons, windows position, and last database changes.
Your tags are already present in the files in your capture, the changes are not reported by the database
Tags in MP4 and VDJ ... are you sure you files were not loaded in deck/prelisten when you tryed to tag them ? VDJ would have silently ignored rename & tags
This problem seems not to affect MP3s
geposted Mon 11 Mar 19 @ 12:17 am
While this is true for the settings file, I believe the database is updated instantly if something changed.
geposted Mon 11 Mar 19 @ 8:55 am
I'm having the exact problem.
Has anyone found solution?
geposted Wed 15 May 19 @ 11:22 pm
Anyone find a fix? I've been having the same problem for months.
geposted Mon 29 Jul 19 @ 2:14 am
What's your tag settings ?
geposted Mon 29 Jul 19 @ 7:18 am
I too faced this problem, but because the external disk was ejected at times by mistake. Setting the setTagsAuto to yes solved the problem
geposted Fri 11 Jun 21 @ 7:58 pm
