Does anyone know if it's possible to add tracks to a playlist using VDJscript? I know you can add to automix using playlist_add and there's a method for adding to virtual folders also. But can't find anything for playlists.
Cheers
Cheers
geposted Fri 12 Apr 19 @ 2:45 am
The way I do it is:
1. Put your selected songs in the SIDELIST or AUTOMIX
2. Open the PLAYLIST you have saved/created so it shows in the browser
3. Select the songs from the SIDELIST or AUTOMIX
4. Drag it over.
It's quick and simple.
4. Drag it over.
geposted Fri 12 Apr 19 @ 3:22 am
Thank's for your help.
It's more a workflow thing. I go through the weekly track downloads and i sort and tag them using assigned midi buttons instead of mouse and keyboard as it's significantly faster. I'd like to assign a midi button to send the selected track in the browser to an "Early doors" playlist, for example. And another button to send it to a "Peak Time" playlist etc.
I can do this with virtual folders but using playlists has certain benefits over folders.
I just thought I'd ask in case there was an script command I was missing!
geposted Fri 12 Apr 19 @ 7:21 pm
here is another quick way to have that PLAYLIST listed into the browser (quickly with a button).
browser_gotofolder "C:\WHEREVER_YOUR_DOCUMENTS_IS_LOCATED\VirtualDJ\Playlists\test.m3u"
then drag the song(s) to be added from the SIDELIST or AUTOMIX
geposted Sat 13 Apr 19 @ 3:48 am
