For reporting any bug, questions or comment related to the latest version of VirtualDJ
(NOTE: VirtualDJ continuously updated, so many older topic on this forum are most probably already fixed in the current build)
If you need extended support, contact our Support Team.
Forum Guidelines  (*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
Topic: VDJ 8.3 B4848 - CRASH EVERY TIME TRY TO RECORD VIDEO MIX
Hello!, My virtual dj 8.3 b4848 crash every time I try to record my videos mix.
It restart but never record. but I can record audio, i can mix videos, the problem is when push the "Star Recording"
I use Pioneer ddj sx2, mac book pro.
I will appreciate your hell..
Thanks!
ps: It never happened with my other vdj version
Thanks!.
geposted Mon 22 Apr 19 @ 4:33 pm
tested with win10 machine and works fine recording even with stacking effects and shaders.
might be just a mac thing?
geposted Mon 22 Apr 19 @ 6:33 pm
locodogPRO InfinityModeratorMember since 2013
Like WCC, ok with win10
What can you tell us elterrible? What o/s, does the problem persist without your SX?
geposted Mon 22 Apr 19 @ 6:42 pm
Have you tried rolling back to a previous build?
geposted Mon 22 Apr 19 @ 6:47 pm
Hi Locodog, I'm using osX el capitan - 6gig - memory
Thanks for your Attention!
geposted Tue 23 Apr 19 @ 6:58 pm
Hi kradcliffe!
I just did a roll back to previous build and no luck :( it just crash and restart the program, but I did notice that it create the file name but it is empty..!
geposted Tue 23 Apr 19 @ 7:03 pm
You need to provide more detailed information.
What format are you trying to record in? Where (which directory) are you trying to record? Have you tried changing the format or the directory?
When you say it never happened with your other version - which version? On the same computer?
geposted Tue 23 Apr 19 @ 7:23 pm
Hi Groovindj, Yes, I did tried 2 formats, web nd mp4, i was using the desktop as folder then I did change it, also the last version was 8.2 b3663.
Thanks!
geposted Wed 24 Apr 19 @ 4:59 pm
