Forum: VirtualDJ Skins
Topic: Kann mein Skin nicht ändern...
Hallo ich habe ein Problem und zwar ich habe mir ein paar Skin angeschaut und bin jetzt auf einem Skin wo ich den einstellungs Button nicht finde. Heißt ich komme nicht mehr aus dem Skin raus, ich brauche wieder den Standort Skin... danke
geposted Mon 06 May 19 @ 8:21 am
You need to post in English here (or use the German forum).
You omitted one piece of vital information. On which skin can you not find the settings button? They all have them.
geposted Mon 06 May 19 @ 8:47 am
All skins have Settings button indeed, but in some it may be a bit "hidden". But anyways, if you use the default keyboard mapping you can use SHIFT+ESC button to open VDJ Settings.
geposted Mon 06 May 19 @ 10:29 am
freppaPRO InfinityMember since 2002
geposted Mon 06 May 19 @ 2:27 pm
He said "ich brauche wieder" - he needs to get back to the standard skin.
geposted Mon 06 May 19 @ 2:54 pm
google translate is our friend ;)
geposted Mon 06 May 19 @ 4:17 pm
geposted Fri 30 Apr 21 @ 6:44 pm
NicotuxHome userMember since 2014
if SHIFT+ESC does not work for some reason
just go to "virtualdj/skins" and delete/rename the corresponding zip file
or ... say which is the skin, setting may be somewhere for sure
i.e. "Virtually Pioneer" hides it in custom setting page with the name Main settings
in most cases this looks like a gear or a tool set
geposted Fri 30 Apr 21 @ 6:57 pm
the post is from 2019 ...
Pretty sure the original poster has figured it out in the 2 years passing since then ;-)
geposted Fri 30 Apr 21 @ 7:26 pm
