Trying to save a Playlist from Automix or Sidelist and it no longer saves. Using v8.3 b4973 - 32Bit / Windows 7 Pro
geposted Thu 23 May 19 @ 7:26 pm
okay, here's what i figured out - it sorta is saving it but NOT renaming it. it made this 'default' list... but i had to right click on it and rename it for the name to stick
does this for both 32 and 64bit
geposted Thu 23 May 19 @ 7:43 pm
Same problem.
Renaming does the trick, but should save it the way you want the first time
geposted Fri 24 May 19 @ 1:36 pm
Will be fixed in next Early Access Build
geposted Fri 24 May 19 @ 2:30 pm
