I found a way of switching crappy pics for better resolution ones. Even tho google and other searches may come up with the pic; you always find yourself with something blurry most times and as you know they look awful when projected on a screen. I don't know if anyone has really discovered it, but I did and here's how you can replace the pic with a better one.
Drag and drop the song in one of your players, go into tag editor, right click on the cover art selection, now right click on tag and click on select a new file and replace it with whatever you want from your own pics. This will most likely give you a better resolution on your second screen or projector screen whichever the case may be. A word to the wise; the higher the resolution, the more memory it takes up on your internal or external drive, but at least you'll have a better picture to show.
Happy Dj-ing from the Dr of Oldies.
geposted Fri 24 May 19 @ 7:43 am
easier fix - don't use cover art, and turn it off. won't have to worry about blurry.
geposted Fri 24 May 19 @ 7:31 pm
You can do that too if you want.
geposted Sat 25 May 19 @ 6:47 pm
