In addition to the "automixMaxLength" option, the "automixFrom CuePoint X to CuePoint Y" option would be very good !!!
geposted Tue 11 Jun 19 @ 10:52 am
Yes!!!
geposted Tue 11 Jun 19 @ 7:41 pm
1+ from me
geposted Tue 11 Jun 19 @ 8:18 pm
I only use automix in a domestic setting, but I sort of think automix points go the wrong way around it.
I'd say mix_in points should be "be mixed in by this point"
mix_out points the same.
but this is just my inexpert opinion and I haven't given it too much thought.
geposted Tue 11 Jun 19 @ 8:39 pm
+1. And additionally , sometimes we don’t need the editor., just drag the mix point with the mouse and that’s it. Like it was use to on VDJ 7.
GK
GK
geposted Wed 12 Jun 19 @ 6:08 am
There are several of them now. It's not like v7 where there only was one. So it's probably not practical
geposted Wed 12 Jun 19 @ 7:38 am
Isn't that what the mix points do?
Not really, your mix out point starts the transition and then you're at the mercy of the mix time. Who thinks in seconds when mixing?
geposted Wed 12 Jun 19 @ 7:52 am
Oh, yes it's an "in this area" feature, with room to mix
But if you want it precise like timeline mixing, wouldn't you use the Automix Editor?
geposted Wed 12 Jun 19 @ 8:16 am
v7 had the same ones.
If you right-click the automix point it will open and select the correct one in the poi editor though, so then you can still drag it with only one click more than v7 (but much more precise waveform)
geposted Wed 12 Jun 19 @ 9:38 am
I never notice on that way. It works.
Thx.
GK
Thx.
GK
geposted Thu 13 Jun 19 @ 12:18 am
that´s exactly what I want
In addition to the "automixMaxLength" option, the "automixFrom CuePoint (X) to CuePoint (Y)" option would be very good !!!
geposted Thu 13 Jun 19 @ 7:53 am
That's what the Automix editor is for!
geposted Thu 13 Jun 19 @ 9:14 am
I can not find an automix editor! where can I find it?
geposted Tue 18 Jun 19 @ 10:33 am
geposted Tue 18 Jun 19 @ 6:31 pm
everyone is waiting for this feature !!!!
geposted Tue 30 Jul 19 @ 11:08 am
Not me - Maybe because they are already there
They are just called mix points instead of cue points
Having separate points (POIs) lets you change you automix without ruining your cue points
geposted Tue 30 Jul 19 @ 2:29 pm
Hallo Klaus,
kannst Du das im deutschen Forum näher Erleutern, habe ich da etwas verpasst !?
Gruß Werner
https://virtualdj.com/forums/230049/German_Forum/Automixplayer.html
Gruß Werner
geposted Tue 30 Jul 19 @ 4:05 pm
>> please integrate it urgently !!!
geposted Wed 21 Aug 19 @ 2:40 pm
Use the AutoMix editor.......
geposted Wed 21 Aug 19 @ 5:18 pm
