im using a decent laptop, but it has a regular wasabi realtek chip. i guess i can make a mix with a mouse? but the way i eq might be difficult. i do have 2 controllers laying around. both have soundcards. but then i would need to plug in some type of external speakers, and where im going (small resort in northern france). its a really quite place.
geposted Sat 15 Jun 19 @ 9:48 am
You can use the controller but still setup the audio to go through the laptop.
geposted Sat 15 Jun 19 @ 9:57 am
was thinking that i found a cable. 2 rca outs to a headphone in? im going to try to get the NI Z1 woking. its small and works well. how exactly would i map it to play so that the tunes come out of the laptop speakers?
geposted Sat 15 Jun 19 @ 11:32 am
On the master line in audio setup, on the second drop down select your internal sound card
geposted Sat 15 Jun 19 @ 1:03 pm
thanks. worked a charm
geposted Sat 15 Jun 19 @ 5:16 pm
