For reporting any bug, questions or comment related to the latest version of VirtualDJ
(NOTE: VirtualDJ continuously updated, so many older topic on this forum are most probably already fixed in the current build)
If you need extended support, contact our Support Team.
Forum Guidelines  (*) The moderators hold the rights to remove, move or modify posts.
Topic: Issue with VDJ / Question about Pioneer 800 controller - mapping
I have 2 questions if you can help me with.
1: For some reason every time I load a track on Deck 1 it continues to change the bpm in sync with deck 2?
2: On the pioneer ddj 800 it has In/out button, relax/exit button and cue/call loop button. I am finding it hard to get my head around this, because I use to have the pioneer ddj SR, I use to to be able to select my desired loop 2/4/8 beats and just press the button.....then filter through the loops back to 1/4 while continuing on loop. Is it possible to have this on this controller? using the relax/exit button to automically active the loop then use the cue/call to filter through 1/2, 1/4/, 1 beats etc....... when I try and do the in/out......it goes completely out of sync and would rather have it simple.....
Many thanks
geposted Fri 12 Jul 19 @ 11:05 am
1. Check if pitch lock or beat lock are active on deck 1
2. Plese read the manual of DDJ-800 to understand better how loops are supposed to work:
http://www.virtualdj.com/manuals/hardware/pioneer/ddj800/layout/decks.html
Items 40 to 46
In short terms:
You use the IN/OUT buttons to set a loop.
Then you use the Call -/+ to halve/double the loop size
Also, holding the IN button will activate a 4 beats loop
Finally: You can remap Reloop/Exit button to "loop"
Also you need to remap the call- and call+ buttons to "loop_half" & "loop_double" in order to use them to set the loop size prior engaging the loop
geposted Fri 12 Jul 19 @ 11:52 am
