It is currently possible to choose colors for any pad & padshift in pads editor
It is also possible to get this color from pads script using pad_color
why is this not possible for padshift ?
i.e. verbs "padshift_color" "padshift_has_color" "padshift_has_action" "pad_has_pressure" "padshift_pushed" do not exist
while this is normal for pad page related verbs :
"pad_has_menu" "pad_has_param" "pad_has_param2" "pad_has_16pads" "pad_pressure_switch" "pad_bank" "pad_edit"
There are missing verbs which are essential in some cases:
action for pad -- equivalent action for padshift
pad - padshift
pad_color - ?? pad editor allows to define one and skin engine handles color for padshift
pad_button_color - padshift_button_color
pad_has_color - ?? pad editor allows to define one and skin engine handles color for padshift
pad_has_action - ?? pad editor allow to define one and skin engine handles action for padshift
pad_has_pressure - ?? pad editor allow to define one and skin engine handles pressure for padshift
pad_pressure - padshift_pressure
pad_pushed - ??
pad - padshift
pad_pushed - ??
geposted Sat 13 Jul 19 @ 11:56 pm
Which controller do you need this for, or what other purpose?
geposted Sun 14 Jul 19 @ 5:54 am
Just other purpose,
I was testing a special pad window with virtual 8x4 matrix of buttons & another pad window with 16x2 sliders (using pressure)
in a way to control external videos windows & master video mix & insert using pads
https://ibb.co/z4X7Dnk
and a calculator pad
https://ibb.co/5FYpWgK
may be usefull for other usage too
https://ibb.co/F8YmhB2
geposted Sun 14 Jul 19 @ 9:06 am
