Today i start Vdj 8 and there is flanger effect on filter knobs. How to return filters back? Was trying to change it in "audio/effects", but it doesn't work
geposted Fri 06 Sep 19 @ 1:58 pm
Click on the word "Filter" you'll see a dropdown menu
geposted Fri 06 Sep 19 @ 2:08 pm
Where should i click on "filter"?
geposted Fri 06 Sep 19 @ 2:10 pm
Ok, got it, thanks a lot)
geposted Fri 06 Sep 19 @ 2:12 pm
That depends on the skin. In the default skin, yes - but there are a lot of skins released before this function existed, and clicking doesn't work on those.
geposted Fri 06 Sep 19 @ 4:32 pm
Soundcolor fx om the filter knobs
Probably the best new feature in VDJ this year :-)
geposted Sat 07 Sep 19 @ 7:02 am
I've just found that feature a few days ago. Awesome sauce.
geposted Sat 07 Sep 19 @ 7:14 am
But they should do it more obvious, because now its just impossible to guess there is option menu. It should looks like button or smth
geposted Sat 07 Sep 19 @ 9:05 am
It was added so that the Color FX buttons on Pioneer controllers "did what they said on the tin".
geposted Sat 07 Sep 19 @ 9:37 am
Had to change to default skin to change this, gotta admit - I'm lovin the filter choices even better.(just hope I don't become THAT DJ who's constantly using it...(hate those mofos lol)
geposted Sat 07 Sep 19 @ 10:34 am
Can be called by script
effect_select "colorfx"
geposted Sat 07 Sep 19 @ 12:20 pm
I don't think there are many skins with this feature at the moment
I find it interesting to implement my skin (Default 6 deck modified), my controller does not have a filter knob, but I use it with the help of SHIFT + GAIN.
for me it would be like having a 5th effect, oh that in my skin I use effects 2, 3 and 4 in the view of 3 effects and in simple view the effect 1
I also see that the key panel has been removed or replaced, but it does not light up when keylock is active
The new changes are not implemented in the touch skin, for example, still unable to use pad_bank2
geposted Sun 08 Sep 19 @ 9:38 am
