since the last 2 or 3 builds the color of hotcue 1 does not show in the skin (neither in customized or default skins)
In the picture I set hotcues 1 and 2 as green, but the button on hotcue 1 does not show the color.
geposted Thu 12 Sep 19 @ 9:06 am
Do you happen to have a custom Hotcues pad page (hotcues.xml file in Documents/VirtualDJ/Pads folder) ? If so, delete the file and re-open VirtualDJ and see if the color for HC 1 is now visible.
geposted Thu 12 Sep 19 @ 11:24 am
b5186 and before hotcue color when set to none used to take deck color and pads also
b5169 all hotcues set to "none" display in pad as red, orange, bleu, yellow, green, violet, cyan, magenta
geposted Thu 12 Sep 19 @ 1:18 pm
What's your 'nonColoredPoi' setting set at ?
geposted Thu 12 Sep 19 @ 5:08 pm
b5186 as "Per-Deck"
b5269 as 'Default'
The function mode of 'nonColoredPoi' have change from Per-Deck, Per-Cue, Fixed White, Fixed Red, Fixed Green, Fixed Blue in previous builds to Default, Deck Color, Different Color, No Color in current early access one
This may be why depending on initial setting the new behavior react differently
b5269 as 'Default'
geposted Thu 12 Sep 19 @ 5:27 pm
Yes, if you want old behavior back change it to "Deck Color"
geposted Thu 12 Sep 19 @ 8:08 pm
I just open the PADS EDITOR and in the pad 1, color, i just put "cue_color 1" and everything went back to normal... so... no bug at all just a miss config that I dont remember doing. Thanks for your reply :)
geposted Fri 13 Sep 19 @ 8:41 pm
