Topic: ns6ll
hipfanPRO InfinityMember since 2010
Just plugged in my new ns6ll and it isnt reading it need to know why
geposted Sat 12 Oct 19 @ 2:01 pm
hipfan wrote :
it isnt reading it
Not enough information....
geposted Sat 12 Oct 19 @ 2:13 pm
Running windows 7 nothin on this just for djing new vdj have had no problems in the last 8 years with my ns7 plugged in a numsrk mixtrac last night no issues. It says the drivers are downloadrd but an error on asio
geposted Sat 12 Oct 19 @ 2:19 pm
Should add i aldo plugged in a sr2 and same thing happend
geposted Sat 12 Oct 19 @ 2:21 pm
Is your Windows 7 32 or 64 bit?
By "new VDJ" do you mean VDJ 2020?
Now the default version of VDJ 2020 is 64 bit, but apparently if you're not running Windows 10 you need to use the 32 bit version.
geposted Sat 12 Oct 19 @ 2:42 pm
64 bit and vdj 2020
geposted Sat 12 Oct 19 @ 2:45 pm
....and is VDJ 2020 32 bit or 64 bit?
geposted Sat 12 Oct 19 @ 2:49 pm
Wont give me the option automatically goes to 32
geposted Sat 12 Oct 19 @ 2:51 pm
OK thanks. I'm just wondering if the NS6 II drivers are 32 or 64 bit, and whether VDJ is annoyed because they're the wrong type...
geposted Sat 12 Oct 19 @ 3:19 pm
Tryin a fifferent computer see whst happens
geposted Sat 12 Oct 19 @ 3:25 pm
geposted Sat 12 Oct 19 @ 3:28 pm
K so it is a computer issue it eorked on a different lsppy.Know i just need to onow how to gety cache songs to the new lappy
geposted Sat 12 Oct 19 @ 3:52 pm
You need to slow your typing down and check your text before you post!
What's the computer that works? Windows 7? 10?
OS = 64 bit? 32 bit? VDJ 32 or 64 bit?
geposted Sat 12 Oct 19 @ 3:57 pm
Ya sorry gettin a little frustrated. Hp windows 10
geposted Sat 12 Oct 19 @ 4:01 pm
OK so now presumably VDJ is 64 bit, OS is 64 bit, drivers are 64 bit and all is well.
geposted Sat 12 Oct 19 @ 4:02 pm
64 bit
Now...can i get my cached songs over
geposted Sat 12 Oct 19 @ 4:04 pm
Thanks to all for the great help
geposted Sat 12 Oct 19 @ 5:21 pm
