Hi All,
I'm having issues getting the PFL/CUE buttons to work on my Pioneer DDJ SX3. I have checked all the mapping options and i have 'PFL' button on the midi as PFL, so I don't believe its the issue. When i turn the mixer headphone knob from cue to master, i can hear what is coming out of the master through the head phones, not doesn't work on the 'CUE' side. I've tried every configuration on my audio options in VDJ with no luck. The thing is that it worked fine when i used the controller back in March. Perhaps a VDJ update stuffed it up?
Please help!!
Rich
Please help!!
Rich
geposted Mon 14 Oct 19 @ 10:57 pm
I'm having the exact same problem. Habe you found a solution yet?
geposted Thu 14 Nov 19 @ 3:31 am
Same issue here... any solution yet?
geposted Sat 28 Mar 20 @ 7:08 pm
Do your audio settings match those in the SX3 setup guide?
geposted Sat 28 Mar 20 @ 7:25 pm
I'm also running into this issue. When I go into the settings for the controllers and try to put the PFLon it acts like I turn it on and then off again right away.
geposted Wed 01 Apr 20 @ 7:39 pm
UPDATE- I did a Factor reset for virtual DJ's settings and it works again :)
geposted Wed 01 Apr 20 @ 8:36 pm
