Topic: Title/Artist wrong
bogartPRO InfinityMember since 2004
Opened 2020 today the title field has the artists name; and the Artist field has the title name.
Opened tag editor and they somehow are switched.
Any one else? Possible solutions?
geposted Tue 15 Oct 19 @ 6:29 pm
LIMOLPRO InfinityMember since 2003
Hello,
a left click on the crossbar of the title, artist And you slide on the left or on the right to change places
geposted Tue 15 Oct 19 @ 6:51 pm
Nope. that's not what it is.
The first input field is Title: under title is the actual artist name.
The Title field always previously showed the actual title.
Sliding the title over just moves the title header, not the actual info.
geposted Tue 15 Oct 19 @ 7:54 pm
Shown a picture
geposted Tue 15 Oct 19 @ 7:59 pm
i would suggest virtualdj could add a button in the tag editor for swap these 2 fields (already suggested in WANF)
geposted Thu 17 Oct 19 @ 4:12 pm
If it was correct in a build before v2020..then this is certainly a bug...but can be easily fixed with tag editing software like mp3 tag(GOOGLE switch artist and title fields)....ps..when using external software to edit files,one should only edit tags..NOT FILENAMES,as this will screw up things with the vdj database...simply close vdj..do your editing..reopen vdj..right click folders edited..and select reload tags..then multiselect and go to vdj's tag editor and rename tracks there..having said this...even if you follow these steps..virtual folders NOT in your root folder will show database errors..as this is a current bug in the software..hope u get it sorted out.
geposted Fri 18 Oct 19 @ 2:14 am
Changed everything back within Virtual DJ.
geposted Fri 18 Oct 19 @ 2:47 pm
