1) For some reason i cannot group samples from a bank together. Other group is working.
2) I installed TAL reverb 4 VST. It works but every time it loads, it resets to default controls..
geposted Wed 16 Oct 19 @ 2:23 am
Same problem, same plugin here. Not ideal, but it's possible to workaround this by editing its .ini file directly (the values in there goes from 0 to 4095).
geposted Thu 17 Oct 19 @ 5:40 am
Update: trying the TAL reverb 4 v2.0.0 beta with 64-bit version of VDJ seem to fix this problem:
https://tal-software.com/products/tal-reverb-4
geposted Thu 17 Oct 19 @ 10:27 am
Thanks i will check that out
geposted Sun 27 Oct 19 @ 4:40 am
Keep in mind your using a BETA vst maybe it has issues.
geposted Sun 27 Oct 19 @ 2:50 pm
