It is possible to place filter folders in virtual folders...why cant we do the reverse?
I have created a virtual folder called 'Master'
In that folder,I created a filter folder with parameters.
Also as a Master subfolder I have a another virtual folder with some files...now i want a folder to show the two subfolders combined.
The makeshift solution is right click "Master" / Recurse.
I thought creating a filter folder in The master virtual folder and setting scope to recursive would work...but that only shows the files from the virtual subfolder..not from the filter folder.
If in the above example..the initial folder(Master) could be a filter folder..and then i cud add the virtual folder as a subfolder..then another filter subfolder with recursive scope..all files would show up
geposted Fri 18 Oct 19 @ 3:45 am
