Topic: Annoying blinking of tooltip rectangles in build 5350
DalainPRO InfinityMember since 2014
I use v8.4-64 b5350, win 10, default skin with PRO layout page.
1. I point mouse over deck waveform and a small rectangle with text like "01:13/02:55" appears under the waveform. I move the mouse away, but a piece of that rectangle remains on screen and starts to blink very fast (near the FX slider).
2. I start prelisten player to play a song with quite long artist name. And place mouse over the green player bar. A rectangle with time/title/artist/year appears. When I put mouse away, the very right part of that rectangle remains on the screen (also blinking very fast).
It was very annoying and I reverted to 5308.
geposted Sat 19 Oct 19 @ 11:19 am
Did you tried following setting?
options/tooltip/no
geposted Sat 19 Oct 19 @ 12:28 pm
Thanks for the option, never seen it before. But it hides them at all.
geposted Mon 21 Oct 19 @ 2:19 am
NicotuxHome userMember since 2014
I got this with some previous builds as well, experimentalSkinEngine off helpped
some tooltips & info stay visible under actual buttons and some goes on raising/disapearing when mouse moved
looks like draw again at mouse position before erasing wrong one :/
with touchscreen they never erase, like waiting for a mouse out
geposted Mon 21 Oct 19 @ 3:34 am
"experimentalSkinEngine"="no" helped, thank you very much!
geposted Fri 25 Oct 19 @ 12:47 am
