Topic: Can't broadcast audio.
Hi
Can someone help? I get the following error every time I try to broadcast audio.
"Ups! Failed to connect to the DJs broadcast.
This broadcast is not reachable. Either the DJs computer has not open port for incoming connections, or the DJ has already ended the broadcast."
"If you have an connection error showing on page here, the DJ might need to open up port 8000 in firewall to be reachable for incoming connections"
Port 8000 is is showing as allowed in the firewall.
geposted Mon 11 Nov 19 @ 11:34 am
I am having the same issue. Been trying to figure it out for a few weeks now.
geposted Mon 11 Nov 19 @ 4:19 pm
You might have to log into your router as well, it can block incoming connection (often even default to block such)
https://portforward.com/
geposted Mon 11 Nov 19 @ 5:47 pm
Many thanks Rune (dj-in-norway). Problem now resolved. Had to create rule for Port 8000 on the wireless router. Changed wifi contracts since I last used broadcast.
geposted Mon 11 Nov 19 @ 6:33 pm
