Jumped into dvs and tried going cheap as possible. Using windows 10, gemini pmx 10, and 2 stanton t.92 turntables. I go through the whole setup of adding timecode and saving. Tweak some settings and practice a bit. After i shut down and restart i have to add the timecode again and some settings are changed. For example i check the crossfader settings and its set to hamster and i never changed to that. And the mixer is set to normal. Some other settings get set different too. Can't find any firmware updates for the mixer either. Any help would be great, thanks
geposted Sat 07 Dec 19 @ 1:29 pm
Ok getting frustrated. I uninstalled vdj and reinstalled. Now when i go to calibrate timecode it crashes every time. I am starting to think its the mixer, and gemini website has no help.
geposted Sat 07 Dec 19 @ 2:39 pm
Based on just your first post, do you have write access to the VDJ settings.xml file? Can you change other settings and they are retained between sessions?
geposted Sun 08 Dec 19 @ 5:09 pm
