Hello,
I can't figure out why recording automatically starts when the Play button is pressed. I checked the mapping and it says Audio Controls > Play/Pause. If i check the mapping of the REC custom button on Vector or Blocks nothing is showing that is it is linked to Play/Pause. Thank you for your help.
geposted Fri 17 Jan 20 @ 1:54 am
I found the problem. I somehow had Record Auto Start turned on in Options.
geposted Fri 17 Jan 20 @ 2:27 am
