Hi, im having a small issue using "Sync" function on the song that is playing, im pretty sure that in one of the upgrades for VDJ 2020 i lost the possibility of syncing the song that its playing with the next one, Im using the latest upgrade of VDJ 2020 on a Mac and a Pioneer DDJ SX3. Everything else is running smooth, i just wish to know if you cancel this option, or do i have to re configure something, im almost 100% sure that in earlier versions i was able to use the sync function on the song that its currently playing. I also use a PC with a DENNON MC4000 and with that set i do not detect this issue.
geposted Thu 13 Feb 20 @ 12:28 am
https://www.youtube.com/watch?v=HA5-YJRvhrk
its still the same .. check the smart options are on as needed
geposted Thu 13 Feb 20 @ 12:49 am
In DDJ-SX3 sound setup try to temporarily remove the line-inputs. Does this fix your sync issue ?
geposted Thu 13 Feb 20 @ 1:51 pm
Thanxx man, that solve it!!
geposted Fri 21 Feb 20 @ 5:53 am
Thank you for the info Bro. I solve it.
geposted Fri 21 Feb 20 @ 5:54 am
I have a Mac which mixes videos in sync without my controller. However, when I connect the DDJ SB2, the right deck always plays faster than the left when beat matched.
Pioneer notes that Mac does not need a driver. How do I resolved this?
geposted Sat 11 Apr 20 @ 3:33 am
