Topic: Text voting
Hello, I believe I seen something about this a while back. Maybe something with firetext but can't find it. Has anyone ever used text voting with VDJ? If so, any info you can provide so I can get this started would be much appreciated.
geposted Mon 02 Mar 20 @ 12:58 pm
I did, but it is years ago.
I'm not sure if the feature was part of iWall or Don's TellyVisuals can do the trick.
geposted Wed 04 Mar 20 @ 9:33 am
Does VDJ 2020 support those add ons stil? I am using the 64 bit version.
geposted Wed 04 Mar 20 @ 9:31 pm
you can have both the 32bit and 64bit version on your computer - I still generally use the 32bit version as the 64bit version of TellyVisuals and TellyMedia is still beta - and because other plugins I use are still 32bit version only.
geposted Thu 05 Mar 20 @ 1:58 am
LIMOLPRO InfinityMember since 2003
Hello,
there is the effect text which works well in 32bits
geposted Thu 05 Mar 20 @ 6:13 pm
Thx, I appreciate your feedback
geposted Thu 05 Mar 20 @ 6:55 pm
I don’t know if this works like that, but I also faced a similar situation
geposted Fri 06 Mar 20 @ 2:32 pm
firetext stopped a long time ago. The main guy raph from Edmonton one day fell off the earth. you can find text voting in telemedia .. click on dons stuff he has a lot of cool stuff , also join the facebook group telimedia
geposted Mon 30 Mar 20 @ 4:46 am
if your still stuck we can chat via pm on here. If your infinity user i can help you out. I build all kinds of stuff
geposted Mon 06 Apr 20 @ 8:21 pm
