In broadcasting audio only through this website using the software only and not powering on my Numark NV controller I get about half of the people that do get the audio and half that can't. I have tried on my phone, tablet and computer using multiple browsers and can't get audio from any of them. Audio out from the software plays through my sound systems but not through any web browsers for me and many people.
I have had over 100 people on facebook attempt to listen via the link for two days now and they do get connected half of them get no audio.
https://www.virtualdj.com/user/Frankedj/broadcast.html
I've been searching the forum and the manual but haven't found anything on this problem that I am having.
geposted Thu 26 Mar 20 @ 8:59 pm
i highly doubt you have the bandwidth to supply 100 people with a stream from your home internet connection. I would shoot for more like 5 maybe.
if you want 100 you will need a shoutcast server that is hosted that has enough bandwidth for that.
also i tested and i can hear your stream fine in firefox browser.
geposted Thu 26 Mar 20 @ 9:33 pm
You can set max clients in settings, check what broadcastDirectMaxClient is set to
Also, you are currently live, but there is no sound. So maybe people are just not listening since there is nothing to listen to.
(unless you forgot to disconnected, and stopped mixing :) )
geposted Fri 27 Mar 20 @ 12:40 am
broadcastDirectMaxClient is at 64. Music still going and showing connected with 1 client. It is a 36 hour long playlist.
geposted Fri 27 Mar 20 @ 12:45 am
making noise here, FF
geposted Fri 27 Mar 20 @ 12:53 am
Ok found an error, will try fix that asap. ..
Seems chrome recent update has changed something, since your pc is not secure https connection it will not allow it.
Works in firefox though..
For today, as user to use this link instead : http://www.virtualdj.com/user/Frankedj/broadcast.html (non https)
geposted Fri 27 Mar 20 @ 1:08 am
Says 5 clients now.
geposted Fri 27 Mar 20 @ 1:10 am
One lady went overboard and was checking lots of things and posted the following: on browsers: Brave, Edge, Firefox and Torch. All of them plays very well. Chrome doesn't give any sound at all for me.
geposted Fri 27 Mar 20 @ 1:12 am
Yes, Chrome has changed something with what connections it allows
For Chrome use this link for now : http://www.virtualdj.com/user/Frankedj/broadcast.html
geposted Fri 27 Mar 20 @ 1:13 am
Llevo 2 años transmitiendo y cada día me gusta más
geposted Sun 22 May 22 @ 6:52 am
