In previous version of VDJ, I used an Extension called "SBDJ StereoChannel" to select which audio channel LT or RT to air when doing karaoke. Some of the songs I purchased years ago has Voiceover on one channel and instrumental on the other. This extension is no longer offered in VDJ. What can I use now to play one of the channels in mono? I want the audio of the selected channel to be heard on all speakers and only silence the VO track. I still have the .exe file to install "SBDJ StereoChannel" but it does not appear in VDJ 2020 after installing it.
geposted Wed 01 Apr 20 @ 12:18 am
maybe your version is old
download again
https://virtualdj.com/plugins/index.html?category=effects&page=2
download again
geposted Wed 01 Apr 20 @ 1:58 am
Too old version or too recent version, the problem : it's 32bit only :(
download VDJ 32bit version that support it
https://www.virtualdj.com/download/pc32
and install it from Settings -> Extensions -> Effects -> Audio Fx
geposted Wed 01 Apr 20 @ 2:21 am
geposted Wed 01 Apr 20 @ 2:24 am
Nice :}
geposted Wed 01 Apr 20 @ 2:46 am
