Hi
I've been trying to add an external cd deck to my setup, the mc6000mk2 will let me input and I can get sound out of the master but if I then do a radio broadcast the external inputs arent picked up.
Anyone ever done this?
I cant work it out.
Thanks.
I cant work it out.
Thanks.
geposted Fri 22 May 20 @ 8:46 pm
https://www.virtualdj.com/manuals/hardware/denon/mc6000mkii/advanced.html
Please make sure you configure an input as "record" and you set Ch 1+2 for it.
Also make sure that the input switch on the rear side of the controller (item 65 on the following page) https://www.virtualdj.com/manuals/hardware/denon/mc6000mkii/layout/rear.html is set to MIC/REC
geposted Fri 22 May 20 @ 8:54 pm
