Topic: DATABASE Won't Open!! :(
J-SnipPRO InfinityMember since 2006
In playing with the camera stuff and with VDJ crashing it has not hosed my database to the point that when VDJ8 opens my stuff is gone. :( What's the easiest way to get it back .. and yes I did have it backed up.
geposted Sat 23 May 20 @ 7:55 pm
*WHEW* Rebooted the computer and it seems to have come back up but I am not going to be able to use the camera function reliably. :( The program locks up too often if things are not done a certain way. Oh well, it was a good idea.
geposted Sat 23 May 20 @ 7:59 pm
locodogPRO InfinityModeratorMember since 2013
if you can't access DB it's usually because a vdj process is still running in task manager. check there next time.
geposted Sat 23 May 20 @ 8:20 pm
