Forum: Wishes and new features
Topic: export/import for VDJ settings
Wouldn't it be useful to have an export/import option for the VDJ settings?
This way, it would be easy to install VDJ on another computer (second computer, system upgrade,...) and have all the preferred settings without having to manually set them once again.
At the moment, not even copy/paste the settings.xml is advisable and "supported":
https://www.virtualdj.com/wiki/How%20to%20Transfer%20To%20A%20New%20Computer.html
"Note : VirtualDJ settings
The settings (preferences) of VirtualDJ are kept in the settings.xml file in \Users\YourUsername\Documents\VirtualDJ folder. It is suggested not to transfer this file to your new computer. The settings.xml file will be automatically created on your new computer when VirtualDJ launches for the first time. You will then need to manually change any settings to your preferences.
If the file is copied and issues occur on first launch, delete the file and re-launch."
geposted Mon 06 Jul 20 @ 3:16 pm
NicotuxHome userMember since 2014
There are a wrongly named "backup database" and "restaure database" functions in the browser options
they backup/restaure everything (but linked covers) in/from file in \Users\YourUsername\Documents\VirtualDJ folder\Backup
geposted Mon 06 Jul 20 @ 3:59 pm
