hello, I am a free user of Virual DJ (without a license, I do not use any professional DJ equipment).
Before I analyzed BPM, this track analysis was retained even after turning off Virtual DJ. Now I don't know what happened, always after turning on the virtual dj again I have to analyze all the songs every time I turn on the new one .... I have a version of VDJ 2020 (5308.1532)
Please help, what could be the problem?
Well thank you
Well thank you
geposted Thu 09 Jul 20 @ 11:14 am
Check that the database file has write permissions.
geposted Thu 09 Jul 20 @ 11:38 am
if you use external drive, the database for songs on that drive will be in the root folder "virtualdj" on that drive
(And every other non-default start up drive)
geposted Thu 09 Jul 20 @ 3:29 pm
it does this both on songs and on an external disk but also on a startup disk ... Macbook Pro (macOS Catalina 10.15.5)
geposted Thu 09 Jul 20 @ 6:33 pm
Hmm.. . check if VirtualDJ has access to write to folders perhaps..
geposted Thu 09 Jul 20 @ 6:36 pm
thanks for the answers, but i still don't know what I should do :(
can you explain it, please?
geposted Thu 09 Jul 20 @ 6:38 pm
Sure its not file permissions as mentioned earlier?
For example if you copied over from other computer, etc
See here : https://virtualdj.com/wiki/Settings-not-saving.html
geposted Thu 09 Jul 20 @ 6:39 pm
Ah, you meant the "File and Folder" .. See here
https://nektony.com/duplicate-finder-free/folders-permission
geposted Thu 09 Jul 20 @ 6:41 pm
fuuu, it will be as hard as I thought ..... well I'll try to study it ....
geposted Thu 09 Jul 20 @ 7:37 pm
security&privacy/ files & folders - Virtual DJ - I have all options checked... :(
geposted Thu 09 Jul 20 @ 7:44 pm
none of these instructions helped me :(
what else could it be?
geposted Fri 10 Jul 20 @ 1:29 am
Strange..
Could try delete settings.xml in /documents/virtualdj/ and then start VirtualDJ.
Alternatively look in settings, and check if you have set readOnly to "yes" (should be "no", else database is in read only mode)
geposted Fri 10 Jul 20 @ 10:24 am
Also check "Full Disk Access" if "Files & Folders" permission didn't work.
geposted Fri 10 Jul 20 @ 10:32 am
nothing.... 😢😢😢
geposted Fri 10 Jul 20 @ 11:11 am
Just to make sure it's a writing DB issue...
Choose a Track from VDJ Browser, right-click->Tag Editor. Try to change the value of one of the fields, e.g PlayCount
Then close and open VDJ again and check Tag Editor for the same track and see if the value you gave was saved.
If not saved, you need to make sure the database.xml (found in /Documents/VirtualDJ folder for Macintosh volume and in /VirtualDJ folder for your External HD) has write permissions, so, right-click on the database.xml file -> Get Info, then look at the bottom for Sharing & Permissions and check if you (your Username) have Read/Write privilege .
One other Q, you installed VirtualDJ from http://www.virtualdj.com/download/index.html and no other place, right ?
geposted Fri 10 Jul 20 @ 12:01 pm
all the settings mentioned so far are fine. also database.xml (read / write permission) and everything else is OK.
The only thing that seems suspicious to me, in the VD folder where database.xml is supposed to be, I have more of these files (database1.xml, database2.xml, etc. up to the number 32) all these databases have read / write permissions
I have VD installed normally from the official website. and everything worked fine before. Just some time ago these problems occurred (probably after some update of mac OS Catalina maybe)
geposted Fri 10 Jul 20 @ 12:24 pm
did u try to change the PlayCount of a track as asked above ? Did the value got saved ?
Also, can you remove/backup to a different folder, all the database X.xml files and leave only the one without number ?
Then see if changing something in the DB, creates some sort of "numbered" database.xl files again.
geposted Fri 10 Jul 20 @ 12:54 pm
I changed the PlayCount, nothing was preserved after closing and relaunching. neither when Analyze BPM nor anything else will remain.
I left only the last number in database.xml and renamed database.xml without a number. no longer generating more numbers. but the problem that everything remains unanalyzed remained ....
geposted Fri 10 Jul 20 @ 1:18 pm
Won't it be the best option in the end to have playlists and what do I need to back up and completely uninstall VD? then reinstall and set everything up?
geposted Fri 10 Jul 20 @ 1:21 pm
That sounds like the document folder is connected with iCloud, and perhaps unsuccessfully so..
With half syncs or what not, and iCloud end up not knowing what to do, so it ends up as copies.
Maybe sort those xml database files by date or size, to figure out which one to keep, and delete the rest (or at least move them out of the folder). And rename the one you keep to database.xml
To start over, and hopefully this time iCloud will work
(alternatively if you dont use iCloud for the VirtualDJ folder, you could perhaps turn it off for that folder)
geposted Fri 10 Jul 20 @ 1:33 pm
