Text elements displaying on top of faders have wrong position upon resize (go to top left of most close parent panel instead of fader)
https://imgur.com/a/H0LrUuk
geposted Fri 31 Jul 20 @ 6:04 am
Then you should contact the creator of the skin and kindly ask them to fix the issue.
geposted Sun 02 Aug 20 @ 6:29 pm
That's his own skin. The issue is with VDJ.
geposted Sun 02 Aug 20 @ 6:45 pm
How does the definition look like?
geposted Sun 02 Aug 20 @ 6:49 pm
Nothing special, it opens ok, works ok but only goes to parent 0,0 upon resize, use again restore correct position
<slider x="+18" y="+0" width="8" height="160" rightclick="temporary" orientation="vertical" action="level" frommiddle="false">
<off color="black" shape="square" border="darker" border_size="1" radius="3"/>
<on color="deckcolor" shape="square" border="darker" border_size="1" radius="3"/>
<mouserect x="-20" y="-10" width="44" height="160+20"/>
<fader width="42" height="26" color="fadercolor" color2="black" gradient="vertical" shape="square" dblclick="level 0% : level 100% : level 0%">
<text dx="4" dy="1" text="≡" fontsize="16" color="gray" align="center"/>
</fader>
</slider>
</fader>
</slider>
geposted Sun 02 Aug 20 @ 7:12 pm
