Cannot record in Master section 2021 version. I followed all instructions, watched instructional video, & read manual. When I get to the message "waiting for sound to begin recording" then press play, the song plays but the message remains "waiting for sound to begin" & does not record any sound, although it creates a file for it. When I load the file it created, there is nothing there, it reads "Unknown file type (Failed to read frame size: could not seek to 1026.)
I also went to all the options and could not figure it out. Thank you! Dana
geposted Wed 05 Aug 20 @ 11:08 pm
I'm guessing, because you've given no clues to your HW profile, maybe your device is a HW mixer. fill in the blanks and we can probably fix it
geposted Wed 05 Aug 20 @ 11:40 pm
I have the same problem. Start to record, it comes up Waiting. Even when I play the song with a controller or not it does not start to record. If I set it to autostart record, the recording is blank.
geposted Tue 15 Sep 20 @ 3:51 pm
Unless your controller has dedicated record loopbac input , you should remove the record line in VDJ Audio setup if you use Master.
geposted Tue 15 Sep 20 @ 4:29 pm
All of these need info about
- HW profile in use (controller, soundboard, ...)
- OS sound config
- VDJ Audio config
fill in the blanks refer to locodog's post
- OS sound config
- VDJ Audio config
