Hi,
When I use "left,right" assignment for deck mapping of a controller, it works fine if I only use one controller...
device_side 'left' ? deck 1 leftdeck ? deck 3 leftdeck : deck 1 leftdeck : deck 2 rightdeck ? deck 4 rightdeck : deck 2 rightdeck
I would like the second controller decks to be affected to the complementary deck of left,right...
Ex . default assignments :
deck A > controller 1, first deck
deck B > controller 1, second deck
deck C > controller 2, first deck
deck D > controller 2, second deck
expected assignments when left permutation is asked :
deck A > controller 2, first deck
deck C > controller 1, first deck
expected assignments when right permutation is asked :
deck B > controller 2, second deck
deck D > controller 1, second deck
expected assignments when both left & right permutations are asked :
I've tried to use assign_controller verb in a script to assign only one deck :
deck 3 assign_controller "Hercules DJConsole Rmx" 1
This sentence change controller assignment for deck 3 but also the assignment for deck 4.
Is there a way to force the change only for deck 3 ?
In the mapping window, it's possible to assign one by one a mapper to 2 non consecutives decks but i can't find the way to script it...
The settings.xml file after change in the mapper section :
<controllersCustomization>
<controller name="KEYBOARD" mapper="KEYBOARD - " />
<controller name="DJCRMX" mapper="Hercules DJConsole RMX mapping" deck="3, 2" />
<controller name="DJCMP3" mapper="Hercules DJConsole MP3 mapping" deck="1, 4" />
</controllersCustomization>
Thanks for your help,
Regards
David
Regards
David
geposted Thu 20 Aug 20 @ 4:58 am
Currently not possible, but will make it possible in a future update using
deck 3 assign_controller "Hercules DJConsole Rmx" 1 1
(The first 1 is the controller index, so the first djconsole rmx, the second one is the deck index, so the first (left) side)
geposted Thu 20 Aug 20 @ 5:07 am
Thanks for your quick reply. Great! Now I'm waiting for this update.
geposted Thu 20 Aug 20 @ 5:40 am
Hello, I've just tested the new functionnality and it works ;)
BUILD 6091 (2020-09-02) : "deck 1 assign_controller 'controllername' 1 1" to assign deck 1 to only the left side of the controller
Thanks a lot Adion !
David
holding? device_side 'left' ? deck 1 leftdeck ? deck 3 leftdeck & deck 1 assign_controller "Hercules DJControl MP3" 1 1 & deck 3 assign_controller "Hercules DJConsole Rmx" 1 1 : deck 1 leftdeck & deck 1 assign_controller "Hercules DJConsole Rmx" 1 1 & deck 3 assign_controller "Hercules DJControl MP3" 1 1 : deck 2 rightdeck ? deck 4 rightdeck & deck 2 assign_controller "Hercules DJControl MP3" 1 2 & deck 4 assign_controller "Hercules DJConsole Rmx" 1 2 : deck 2 rightdeck & deck 2 assign_controller "Hercules DJConsole Rmx" 1 2 & deck 4 assign_controller "Hercules DJControl MP3" 1 2
David
geposted Tue 15 Sep 20 @ 4:11 am
