Hi guys,
I want to use my own music archive as an online catalog for VirtualDJ. Should I do it with plugin or is there some simpler way like implementing an API?
geposted Fri 28 Aug 20 @ 9:45 am
using ASK THE DJ you can optionally upload your catalog ...
https://www.virtualdj.com/manuals/virtualdj/interface/database/askthedj/index.html
geposted Fri 28 Aug 20 @ 9:55 am
its a XML database
use an XML database script or application and it should do the trick
geposted Fri 28 Aug 20 @ 10:29 am
and you can recurse the database, sort it in browser view and then export browser view with selected columns only, in csv or html format
VDJ often have many solutions
geposted Fri 28 Aug 20 @ 11:26 am
user22318197 wrote :
Hi guys,
With a plugin, maybe, but without, there isn't really any way you can directly handle the search queries you enter into VDJ.
What you can do however is enable logUnseccessfulSearches, parse the TXT file with whatever you want and then do some action like editing the Automix or Sidelist playlist files. I'm not sure when those get reloaded, if at all. It may be that VDJ only reads them at startup and only writes from RAM during runtime, but might be worth a shot.
geposted Fri 28 Aug 20 @ 7:36 pm
