Hi all,
I'm not sure if this feature is available on VDJ, But I cannot find any information. I have tons of 70 and 140 BPM songs and sometimes I need to jump 70 to 140 or 140 to 70. I use the Folder filter "Bpm Difference < 5" but it only shows the similar BPM songs. Is there any way to have double/half BPM songs in the same list? like 140, 70, 69, etc... for better live DJing!
Thanks!
Thanks!
geposted Thu 10 Sep 20 @ 11:53 pm
(bpm>65 & bpm<75) | (bpm>135 & bpm<145)
geposted Fri 11 Sep 20 @ 8:24 am
thank you! but it seems it's not for live search…
geposted Fri 11 Sep 20 @ 1:05 pm
locodog's maths are VDJ maths ... ;)
(bpm>65 & bpm<75) | (bpm>135 & bpm<150)
geposted Fri 11 Sep 20 @ 1:37 pm
I am trying to solve a similar problem and tried this filter ...
(BPM > 40 and BPM <= 50 and BPM difference > 35 and BPM difference <= 50) or
(BPM > 50 and BPM <= 60 and BPM difference > 45 and BPM difference <= 60) or
(BPM > 60 and BPM <= 70 and BPM difference > 55 and BPM difference <= 70) or
(BPM > 70 and BPM <= 80 and BPM difference > 65 and BPM difference <= 80) or
(BPM > 80 and BPM <= 90 and BPM difference > 75 and BPM difference <= 90) or
(BPM > 90 and BPM <= 100 and BPM difference > 85 and BPM difference <= 100) or
(BPM > 100 and BPM <= 110 and BPM difference > 95 and BPM difference <= 110) or
(BPM > 110 and BPM <= 120 and BPM difference > 105 and BPM difference <= 120)
Seems to work almost as I want !
geposted Sat 28 Jan 23 @ 6:44 pm
Ist IT possible to use it with get_bpm of the Last loaded track?
So i can only See Tracks wich a fits incl half and Double bpm?
geposted Sat 25 Feb 23 @ 8:02 pm
yeah it is, I've done it, I'm working on a thing that this is a small part of a bigger thing.
look out for it, it's a point & click adventure, but it does stuff quick filters don't quite do, [OR logic, being a serious deviation to current quick_filter methods]
without creating a plugin, script a custom_button as so
that results in +- 4% @ 1 times, scaled for 0.5 times & 2 times
it's not rocket surgery, but if you don't have the vdj script basics, and if it works wrong just pm me.
quick_filter 0 ? on & quick_filter off : off & get_text "( Bpm < `param_multiply 1.04 'deck master get_bpm'` and Bpm >`param_multiply 0.96 'deck master get_bpm'` ) or ( Bpm < `param_multiply 2.08 'deck master get_bpm'` and Bpm >`param_multiply 1.92 'deck master get_bpm'` ) or ( Bpm < `param_multiply 0.52 'deck master get_bpm'` and Bpm >`param_multiply 0.48 'deck master get_bpm'` ) " & param_cast 'text' & quick_filter & search "*"
geposted Sat 25 Feb 23 @ 10:23 pm
Thx Loco, i will Test IT next time.
geposted Mon 27 Feb 23 @ 6:05 am
I posted a somewhat related question here ...
https://virtualdj.com/forums/254212/VirtualDJ_Technical_Support/automatically_play_a_song_with_a_BPM_slightly_faster.html
if anyone can help ;-)
geposted Tue 29 Aug 23 @ 4:16 am
