Hi everyone, i'm finally playing around with the stems feature and finding it a lot of fun, the creative juices are flowing.
Is it possible to record samples from tracks playing in say deck A but with some stems isolated.
EG: When I record a sample with Vocals turned off, i.e only intend to capture the backing track and video, the sample is created BUT with vocals still in it...
A little confusing. Any help and guidance MUCH appreciated.
geposted Tue 15 Sep 20 @ 8:11 am
as far as I can tell you have to record the samples from the Record tab as main audio output and not from Loop Record in the loop panel
geposted Tue 15 Sep 20 @ 10:20 am
after some consulting... may be wrong.. but I've not been able to record a sample from Loop Rec with stems enabled
geposted Tue 15 Sep 20 @ 10:50 am
Yes this is true
recording from Loop Rec VDJ will only record startpoint and endpoint and extracts a part of the track, not a real record of the playback
(the same, effects do not apply)
geposted Tue 15 Sep 20 @ 10:52 am
I works for me... Strange...
EDIT: Both samples still work as expected (with/without vocals) even after a VDJ restart, so it's not because the track is still loaded or the vocal stems is still off
