Hi - been playing around with the Stems feature which is great. I am using a Denon Prime 4 and isolating the stems with the pads.
2 questions - is there a button on the Prime 4 that is mapped to activate Stems on the pads? The Hotcue button, Loop Rolls etc actually activate what they should, but can only get to Stems via the laptop itself.
Second question - is there a way to bring back all the stems as active rather then pressing each one individually? I would like possibly, if I'd taken it down to just vocals for example, with one press bring everything instantly back if that makes sense.
Thanks!
Thanks!
geposted Wed 16 Sep 20 @ 2:51 pm
For the second question:
I use this to enable all 5 simple stems whatever their state are :
only_stem MeloVocal & only_stem rhythm & only_stem Rhythm ? only_stem Rhythm : only_stem MeloVocal ? only_stem MeloVocal : nothing
geposted Wed 16 Sep 20 @ 3:17 pm
When You go in the Pad Dropdown , on top you see Page 1 2 3 4 and the shift is the second feature for this button 1 2 3 4 .
There can you change which Padpage the Button opens.
when you change on Page 1 a other Padpage , Stems , then the Button opens the Stems Padpage , and not the Cue Padpage.
And the same you con Change by all other Padbuttons.
This have not to do with the mapping.
geposted Wed 16 Sep 20 @ 5:51 pm
