I have an older backup laptop on Windows 7 (which I never connect to the internet and don't want to upgrade to Windows 10). Can I still download VDJ 2020 32-bit for it?
I have a Pro Infinity license.
Thanks!
Thanks!
geposted Sat 03 Oct 20 @ 12:36 pm
https://virtualdj.com/download/pc32 (32-bit, version 2020)
https://virtualdj.com/download/pc (64-bit, version 2021)
geposted Wed 14 Oct 20 @ 10:33 am[ selected best answer by Rune (DJ-In-Norway) on Tue 24 Nov 20 @ 3:03 pm ]
sure, grab a copy here
http://www.virtualdj.com/download/build.html
geposted Sat 03 Oct 20 @ 12:38 pm
Oh great, not sure why I couldn't find that, thanks!! :)
geposted Sun 04 Oct 20 @ 1:51 am
Because it is difficult to find, last bottom right link of "History" section of the wiki : https://www.virtualdj.com/wiki/index.html
geposted Sun 04 Oct 20 @ 2:21 am
Also if you visit the regular download page from your windows 7 pc it will show you directly the 32 bit version download
geposted Sun 04 Oct 20 @ 5:59 am
.....but he never connects it to the internet.
geposted Sun 04 Oct 20 @ 9:50 am
For a certain win 7 laptop with good reason.
geposted Wed 07 Oct 20 @ 10:02 pm
Will your cues points and playlists stillbe there or will you have to redo them all?
geposted Fri 09 Oct 20 @ 3:17 pm
Downloading VDJ will not delete files from your computer.
geposted Fri 09 Oct 20 @ 3:53 pm
Can also download directly here:
Selected as best answer geposted Wed 14 Oct 20 @ 10:33 am
Hello. I just bought a new windows tablet only problem it runs 32 bit! I just bought a party mix pro to use with the tablet. Does anyone know if any of the 32 bit builds support the party mix pro? Im at my whits end here. Thanks
geposted Fri 13 Nov 20 @ 10:47 am
The 32 bit builds are as up-to-date as the 64 bit version. The only difference is the stems functionality - that's 64 bit only.
geposted Fri 13 Nov 20 @ 10:52 am
That will work fine yes ;-)
geposted Fri 13 Nov 20 @ 2:14 pm
Whats the best Virtual DJ 2020 32-bit version to use with Mac?
geposted Tue 24 Nov 20 @ 7:49 am
There is no 32-bit version for mac
geposted Tue 24 Nov 20 @ 8:05 am
Whats the best version to use with a MacBook pro 2016 and 2012?
geposted Tue 24 Nov 20 @ 9:31 am
The latest.
If you are still using macOS 10.7 or 10.8 you can find the latest supported version here
https://www.virtualdj.com/wiki/Minimum%20system%20requirements.html
geposted Tue 24 Nov 20 @ 9:40 am
I've had virtual dj 2021 freeze up on a pc.....heard that there are way less issues with vdj 2020. Which build has the least issues on mac? Using Catalina and Mojave. Im just worried about my mac freezing up in the middle of a shift at work.
geposted Tue 24 Nov 20 @ 9:42 am
geposted Tue 24 Nov 20 @ 10:05 am
You heard? Ok...
Then maybe don't ask in this group - we usually talk facts here - not hearsay
(comments like that always makes me mad, because they are so damaging to all users)
geposted Tue 24 Nov 20 @ 11:52 am
