I have a fairly basic question... this might have been asked countless times as it should be the most basic feature... but could you please help/guide to simply auto play track on "track load"
I am having difficulties to achieve this even on DVS mode and that's quiet shocking to be fair. Can't see myself leaving the turntable to press play and prepare my mix.
For the record I'm on VDJ V8.5 b6106 using the most powerful MBP to date.
Thanks
Thanks
geposted Mon 05 Oct 20 @ 1:25 pm
I don't think you can do this with Drag & Drop, but you can remap your load button to
load & play
geposted Wed 07 Oct 20 @ 11:21 am
make sure loadsecurity is off
you may also test load_next "keepplay"
geposted Wed 07 Oct 20 @ 2:38 pm
Yes, it also works with drag and drop. Go to the keyboard mapping, search for the action "OPSONGLOAD" and put in the command "play". It will trigger the command as soon as the song will be loaded into any deck.
geposted Wed 07 Oct 20 @ 5:32 pm
Here's your fix for anyone looking to achieve this MINOR feature which in fact should be a default.
Select keyboard map and then.... ONSONGLOAD -> timecode_active ? play : nothing
Have fun!
Have fun!
geposted Sun 18 Oct 20 @ 3:53 pm
Default? Really?
Do you really want the music to instantly "run away from you" when you are in a DVS setup?
That would be ... pretty bad I think
geposted Sun 18 Oct 20 @ 4:01 pm
klausmogensen wrote :
Default? Really?
Default? Really?
Not at all... that's how it should be. But I accept your opinion.
geposted Tue 20 Oct 20 @ 8:11 am
