Forum: VirtualDJ Plugins
Topic: Correspondence between frequency in hertz and float number
What is the correspondence between a float (number between 0 and 1) and a frequency ?
For example for a high pass filter :
- cut at 150 Hz = float(x.xx)
- and vice versa float(0.35) = x Hz ?
geposted Thu 22 Oct 20 @ 2:19 pm
Not sure I think it's dial² interpolated over 20Hz to 20kHz, it might even be dial³
geposted Thu 22 Oct 20 @ 3:06 pm
There's no fixed rule here, so depends a bit on what you're making which part of the frequency range is more important to you.
For the default filter the range is indeed cubed, but for the echo it's linear for the high pass and squared for the low pass.
geposted Thu 22 Oct 20 @ 3:30 pm
how about the native separate filters, [something I thought about be never checked]
geposted Thu 22 Oct 20 @ 3:36 pm
Also cubed, but over the range of the entire knob instead of only half.
geposted Thu 22 Oct 20 @ 4:19 pm
TexZKPRO InfinityMember since 2005
I'm using a cubic mapping as well.
geposted Sun 25 Oct 20 @ 7:58 pm
mmmmhhh .. I don't really know how to use or enter equalizer frequencies in an effect ..
But in the program itself I have set it that way.
There it is entered in Hz
geposted Mon 26 Oct 20 @ 3:46 am
@djdutschi, entirely different thing.
geposted Mon 26 Oct 20 @ 12:51 pm
That may be true. But there are also a couple of effects that access the equalizer frequencies ;-)
That's why I wrote this.
geposted Mon 26 Oct 20 @ 5:34 pm
I realized that my question is silly because I was taking the problem backwards.
Just determine a frequency in hertz (example 500 Hz) and use it as it is in a formula like w = 2 * PI * 500 / SampleRate
geposted Sat 07 Nov 20 @ 10:33 am
