Dear VirtualDJ community,
(former) Traktor user here who is trying out VDJ and is thinking about switching to the Pro Version of VDJ. I’d also like to add a touch strip controller to my new setup. Why? Because I like to jump between different effect or eq parameters with just a single finger tip (custom buttons are not what I am looking for).
I saw that VDJ already supports some touch strip controllers like the Stantons SCS.3 System, but several VDJ users seemed to have problems with the mapping (see: https://www.virtualdj.com/forums/137892/Old_versions/Stanton_SCS_3m_System___Virtual_Dj_-_need_some_help_setting_it_up.html ). There’s also a mapping for the Keith McMillen QuNeo, but I heard that it's hard/complex to map(?). I didn’t find any mapping for Native Instruments Maschine Jam, though.
So can anyone recommend a touch strip controller to me that supports multitouch and can be easily mapped to VDJ? (It can also be one of the above mentioned controllers). Do (these) touch strip controllers have a big latency?
Thanks in advance,
Zabie
Thanks in advance,
Zabie
geposted Sun 22 Nov 20 @ 3:32 pm
as an add-on or extra controller?
Many main controllers already have touch strip at the decks, but I guess you might mean extra controller.
Perhaps something like Korg nanoPad would be of interest, both performance pads and a touch pad (YX) suitable for effect params, etc (and already ready for VirtualDJ, supported)
Pioneer XP1 and XP2 also have a strip and more...
https://www.virtualdj.com/products/hardware.html?category=addon
The Stanton thread you referred to is 10 years old.
And was ended with the user saying he just changed midi channel "and it works perfectly" (see bottom)
So perhaps that also works well but I have never tried it
geposted Sun 22 Nov 20 @ 6:52 pm
And its quite easy to map any not already supported controller ..
The QuNeo should work just fine if you map it yourself
https://www.virtualdj.com/wiki/How-do-I-map-my-MIDI-controller.html
And already is, the mapper is a bit old, but probably still works fine, and easy to update should there be need for anything
http://www.virtualdj.com/addons/15999/Quneo
geposted Sun 22 Nov 20 @ 6:54 pm
Thanks a lot!
I saw that one user said he managed to solve the problem with Stanton SCS System, yet there are many users on other sites including YouTube who still (?) seem to have problems. Well, I'll probably just take one of these and try out myself!
geposted Mon 23 Nov 20 @ 6:10 pm
pioneer xp1 seems about the same price as Quneo and much nicer :-)
https://www.amazon.com/Pioneer-Pro-DDJ-XP1-Sub-Controller/dp/B075NFN8YH/ref=sr_1_2?dchild=1&keywords=pioneer+xp1&qid=1606164026&sr=8-2
geposted Mon 23 Nov 20 @ 8:41 pm
