I recently downloaded the latest version of Virtual DJ 2021 Build b6156 on my mac running Big Sur 11.1. It keeps crashing mac every time I close the app. It is also crashing when I click 'yes' on the dialog box that asks if it should load the menus for the new version. Is there another build or version compatible with Big Sur?
geposted Mon 21 Dec 20 @ 5:55 pm
No problem here.
You could try the latest Early Access release here: https://www.virtualdj.com/download/build.html
Or try to enable experimentalUseMetal in options
geposted Mon 21 Dec 20 @ 6:09 pm
Hello,
Closing VDJ 2021 b6242 consistently crashes macOS Big Sur 11.1 on a Mac mini 2018.
It does not matter what sound card I use. The one from the Mac mini or the one from the Thunderbolt Display or an external one.
Reinstalling VDJ does not help.
Deleting the /Documents/VirtualDJ folder does not help
This is very annoying.
Tun
Tun
geposted Wed 13 Jan 21 @ 5:12 pm
Se corta el audio al principio de la reproducción del disco hasta que no se cargue toda la canción en el reproductor, a que se debe eso, uso Macbook en el Os Big Sur
geposted Sat 13 Feb 21 @ 11:28 pm
Hola. hace varios meses que me encuentro mezclando con mi pionner DDJ-RR, y se corta con un sonido tipo BIIIIIIIIPPPPPPPPPPPPP. tengo cuenta infinity y realmente no se que puede ser.
geposted Sat 08 May 21 @ 10:52 pm
For those using Big Sur the latest version is Big Sur 11.3
......and VirtualDJ is (early Access) v8.5 b6439
I've never had a crash with this setup.
System Specs;
MacBook Pro 15” 2017 (Touch Bar), 2.9 GHz Intel Core i7, 16 GB 2133 MHz LPDDR3 Memory, Radeon Pro 560 4096 MB, Intel HD Graphics 630 n1536 MB, macOS Big Sur 11.3, 500gb SSD Bootcamped with Windows 10 Pro ver. 20H2 build 19042.964 x64bit . External WD Passport Ultra 2Tb HD containing Music & Video databases and is formatted NTFS, I use the Paragon plugin with NTFS for Mac.
VirtualDJ 2021 b6439 and Controllers - Denon MC7000, Denon MC6000 MkII.
System Specs;
geposted Sat 08 May 21 @ 11:34 pm
