Topic: trying to get 3 colors for a pad based on action
I've got a button that works fine, using the holding script -
holding ? stem_pad 'bass' & stem_pad 'instru' & stem_pad 'kick' & stem_pad 'hihat' : stem_pad 'vocal'
press it = take out vocal stem
hold it = take out all the instrumental
just trying to get the color to change based on the mode...so for example
stem_pad 'bass' & stem_pad 'instru' & stem_pad 'kick' & stem_pad 'hihat - the color will be blue
stem_pad 'vocal' - the color is violet
and then when neither are active it's red
seems easy...sorry if it's covered somewhere else. Whenever I search VDJ it says to refine my search..but then I refine it too much and can't find anything!
lol thanks in advance
geposted Thu 14 Jan 21 @ 6:30 am
NicotuxHome userMember since 2014
It's not so hard
when editing pads there is a tab named "color" just script
stem_pad 'vocal' ? color violet : color blue
and the pad itself : you can try things like this
holding ? stem_pad isolate vocal : stem_pad vocal
geposted Thu 14 Jan 21 @ 7:49 am
