loaded VDJ2020, asked if I wanted to update to the newest, as always I say yes wanted to keep everything up date, the Shaders visuals would allow you to auto rotate, and or by audio. I had been downloading a lot of the shaders last few weeks, auto rotavate has been work until yesterday after the update 1-20-21, now even after checking the box for auto rotate does not work, I now have to physically click on each shader. Any help would be awesome thank you
geposted Thu 21 Jan 21 @ 8:10 pm
I don't know why you have an issue with the auto-change feature. It works ok for me in the latest version
But because it's always 32 beats I find it too limited, so locodog helped me build a script where you can change the length
I then build that into a pad page so i can control it
Here is the video about it, and there are links in the description to the resources you may need:
geposted Fri 22 Jan 21 @ 10:15 am
