With your help I have created a great ONINIT that set VDJ up when it starts, saving many clicks.
The last change is to set the Fx Panel on the Default Pro skin to "FX x3 (full)".
Currently, "Pads 16" appears after restarting VDJ most of the time.
I have tried to uncheck the "Pads 16" in the selection menu, and it continues to be re-selected and the active Fx Panel when starting VDJ.
How can I either stop "Pads 16" from becoming checked, or have "FX x3 (full)" the active Fx panel when starting? (see pic)
No matter how many times I UN-check "Pads 16", on restart it is checked, and is the active Fx panel.
I have found these possible actions:
skin_panel
skin_panelgroup
skin_panelgroup_available
and have been unable to get them to hide or make the "Pads 16" panel unavailable.
Or is this done in the skin.xml file?
Thanks in advance.
skin_panel
skin_panelgroup
Thanks in advance.
geposted Sat 13 Feb 21 @ 11:05 am
pad_bank2 off
and assure settings -> Options -> controls : sixteenPadsMode is set to auto
as there is no off this highly depends on controller
geposted Sat 13 Feb 21 @ 11:31 am
skin_panel '@fxknobs_deck1' & skin_panel '@fxknobs_deck2'
geposted Sat 13 Feb 21 @ 12:25 pm
Thank you Locodog
That helped a lot understanding how to address the panels.
during those times that "Pads 16" is not appearing, it did not work as expected since the script seems to toggle.
Would be best if there was a way to just specify the panel one wanted to display. I cannot figure out how to do that.
As a workaround created this script which works, for different situations is:
for ONE deck, only deck 1.
If I want to set both decks 1 and 2 then there are 2 possible startup configurations, requiring this still simple script:
If I want to setup 3 decks ( 6 configuration) this script becomes way to awkward.
(I could paste that here but would not help lead to a solution)
And head hurts thinking about having a script for all 4 decks with now, 12 possible configurations.
Is there an easier way?
Is there a way to specify the group for the Fx panel, with a script?
trying to understand how to use skin_panelgroup and skin_panelgroup_avail
what I can find is:
which does not include skin_panelgroup_avail, which is only shows
and would be great if I could figure out how to not have the '@pads16' available.
(could remove it from the skin, but may want to use it, at times) (requiring switching skins when wanting to use the Pad 16, which I can be done with a custom button. again big workarounds)
PS I don't understand how to use both, skin_panelgroup and skin_panelgroup_avail
since
the above and many other attempts all do NOT work, to set the Fx panel to "FX x3 (full)"
skin_panel '@fxknobs_deck1' ? nothing : skin_panel '@fxknobs_deck1'
skin_panel '@fxknobs_deck1' ? skin_panel '@fxknobs_deck2' ? nothiing : skin_panel '@fxknobs_deck2' : skin_panel '@fxknobs_deck1' & skin_panel '@fxknobs_deck2' ? nothiing : skin_panel '@fxknobs_deck2'
what I can find is:
since
skin_panelgroup 'fx' '@fxknobs_deck1' & skin_panelgroup 'fx' '@fxknobs_deck2'
skin_panelgroup 'fx_[PANELNAME]' '@fxknobs_deck1' & skin_panelgroup 'fx_[PANELNAME]' '@fxknobs_deck2'
geposted Sun 14 Feb 21 @ 5:31 am
skin_panel '@fxknobs_deck1' on & skin_panel '@fxknobs_deck2' on
geposted Sun 14 Feb 21 @ 6:27 am
Big Smiles @ Locodog
Thank you and so simple
You Rock !
You Rock !
geposted Sun 14 Feb 21 @ 7:26 am
Thanks locodog
I used this variation to get the fx3 panel :
skin_panel '@fxsliders_deck1' & skin_panel '@fxsliders_deck2'
geposted Wed 29 Jun 22 @ 3:51 am
