vdj asks every time it boots to download 2021,,,, its the same thing i already have how do i stop that...... I have pro infinity
geposted Fri 26 Feb 21 @ 11:07 pm
It's probably new builds of VDJ2021 - there has been 10-15 different full public versions of VDJ2021 by now
However you can turn it on by disabling auto updates in the settings
If you still get a pop-up after that there may be 1 update already on your laptop ready to be installed (depending on your previous setting). Then you may need to remove that update file
geposted Sat 27 Feb 21 @ 7:10 am
If the auto update gets stuck, try download and run the full installer from here:
https://www.virtualdj.com/download
That will put you on latest and greatest ;-)
geposted Sat 27 Feb 21 @ 10:47 am
When you open the Settings, look in the lower left corner. It will show you the version number. Right now the lastest seems to be:
v8.5-64 b6294
The version 8.5 seems to stay the same most of the time. The bxxxx changes. That appears to be the build number. I suspect each time you update, you're getting a new build. So it probably is updating, even if it doesn't seem to be.
--CP
v8.5-64 b6294
--CP
geposted Sat 27 Feb 21 @ 3:12 pm
