I've discussed this problem before. Out of nowhere (no upgrades selection) my cue points, etc. no longer shows up on VDJ program. Where are they?
geposted Wed 07 Apr 21 @ 3:38 am
They should be hosted inside this file:
D:\VirtualDJ\database.xml
Where D: is the letter of your external drive.
Perhaps you deleted/renamed/moved that file/directory ?
geposted Wed 07 Apr 21 @ 6:31 am
i am having that same issue i switched laptops and my new laptop changed to D my old laptop was F. Do that make a difference I copied everything from the old to the new and it seems like some cue points arent the same
geposted Wed 07 Apr 21 @ 10:08 pm
