I can't change it on my live broadcast.. And when I force it there is a broadcast error saying the station cannot authenticate or something like that.. I need to go live on the air in less than 2 hours.. Please help!!!! Thanks
geposted Fri 23 Apr 21 @ 1:20 pm
dj_gabeusmc wrote :
Istation cannot authenticate or something like that..
usually means wrong password, or mount/channel.
In other words incorrect broadcast credentials
Check with the server you are broadcasting to what they require
geposted Fri 23 Apr 21 @ 1:52 pm
