Topic: Macbook Pro 2017, DDJSZ, VDJLE8, question
Just installed VDJ LE 8 on my 2017 MacBook Pro. I have Safari and I am using the Pioneer SZ.
Do I need any firmware updates? If so, should I go to VJ in my account to find them or do I need to visit Pioneer Pro DJ?
Thanks!!
geposted Sun 25 Apr 21 @ 2:27 pm
geposted Sun 25 Apr 21 @ 2:41 pm
geposted Sun 25 Apr 21 @ 2:42 pm
Much appreciated! :-)
No, this is all brand new. New Mac, and I just downloaded VDJ LE 8 from my Virtual DJ account. All is current.
geposted Sun 25 Apr 21 @ 2:43 pm
I don't want to use VDJ 2020, so I downloaded the next available which was VDJ LE 8
geposted Sun 25 Apr 21 @ 2:44 pm
Would strongly recommend 2020
But up to you of course..
2020 version has had years of improvements, new features, new effects, stems, stability and performance etc
geposted Sun 25 Apr 21 @ 2:49 pm
I am just weary of problems. I have no issue going to the new version, but I don't want issues popping up. I can take your word though that it's solid. Do I need to uninstall VDJLE8 or does it just overwrite to the new version (2020)?
geposted Sun 25 Apr 21 @ 2:54 pm
Just install 2020
You will even have both versions in your computer
so its no risk in it :) can still run LE
geposted Sun 25 Apr 21 @ 2:55 pm
Thanks!!
geposted Sun 25 Apr 21 @ 4:35 pm
I downloaded the latest Virtual DJ 2020, but I cannot find it on my Mac anywhere. All that keeps showing up is Virtual DJ 8 which I downloaded first. I have a Mac 2017, OS Mojave.
Any help would be appreciated. Thanks!
geposted Tue 04 May 21 @ 6:14 pm
Just downloaded ? If so in your download folder...
And if installed it might stay say "virtuald 8" at a shortcut that didnt get renamed or similarly
Open the software, look at bottom of license tab in settings, if its say VirtualDJ 2021
geposted Tue 04 May 21 @ 9:25 pm
